1993 Dakota issues
Old Aug 6, 2025 | 10:15 PM
Agedcheese's Avatar
Agedcheese
I haven't rebuilt an engine in years. Elderly eyes, hand tremors and so on make it nearly impossible. On the other hand, the major tune up I expected to take a couple of weeks actually took nearly 2 1/2 months. I found broken bolts in the heads to drill out, failing parts that hadn't failed, yet, and I had just retired and it was a hot summer so I didn't push it as hard as I would have when time was short.
At 135K you still have a solid engine that may just need some attention. Find a small shop and have them do a vacuum check and see what all you might need. I suspect you might just need the intake retorqued. Don't tell them the problem, just detail the symptoms. That way they will look and not just throw parts at it.
Sounds good, thanks a bunch!
