new motor
Old Jan 27, 2006 | 01:41 AM
badassxr50r's Avatar
badassxr50r
Default new motor
ok i wanna get a 1990 dakota or older and do a motor, tranny, rearend swap in it.. ok well i have a built 318 in my dodge aspen right now right along with the auto tranny and a 8.25 rear end with 3.55 and limited slip... what i want to know is what else i need to do the swap i mean i know hoses and maybe a radiator.. oh i also have an electric fan for it too what else will i need thanks!!!
Old Jan 27, 2006 | 09:15 PM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: new motor
Computer for the tranny, and or engine. Mounts. Wiring.
What year motor?
Old Jan 28, 2006 | 05:04 AM
badassxr50r
its a 1977 318 has a 600cfm carb but im gunna up it to a 650 since its built
Old Jan 28, 2006 | 06:25 AM
badassxr50r
ORIGINAL: 360DakotaPwr
What year motor?
why would i have to have it for the motor or tranny both are from 1977 so the tranny shifts on its own... the only reason i can see to have it for the motor is ignition?? also with this swap will it sit there and have a check engine light on all the time?? also will it pass emissions??? what will i have to do to make it pass??
Old Jan 29, 2006 | 02:31 AM
injmopar's Avatar
injmopar
You are right ,no aspen ever need a computer.In fact not even a 90 needs a computer for the trans. And the ignition is best handled by the 77 setup.And if you us an aftermarket Ign box like a " Standard 101" it will rev to the limit of the cam
Old Jan 29, 2006 | 07:30 AM
badassxr50r
nice thanks for the info!!! so will it be easy to do the swap just mounts and exhaust?? also will the "computer" from the aspen work ok?? is there a place to bolt it on?? also with the tires on the dakota with the 3.55 gears and the tq904 what kinda rpm am i looking at on the highway cuz i know the wheels and tires on the aspen now its at 3,000rpm at 60mph!!! maybe i can get taller tires for the dakota to bring down the rpm's?!?!?
Old Jan 31, 2006 | 01:54 AM
360DakotaPwr
Yes as long as you keep out of the electronic trans range its cool. I wasnt sure what exactly you wanted to run. I meant that if you went with a 1990 dakota tranny.
Old Jan 31, 2006 | 06:32 AM
badassxr50r
oh ok i see well its a 77' tranny, motor and rearend so in other words ur saying i can just throw away the computer??
Old Feb 1, 2006 | 12:49 AM
badassxr50r
would all the work be the same if i got a 93 dakota???
Old Feb 3, 2006 | 02:25 AM
360DakotaPwr
You should not need any computers for 1977 stuff. If you go with 93 drivetrain, then you will need an engine/tranny computer. The trans for the most part is controlled by fluid pressure, but it would work best with the computer. As far as going with a carbourated motor, and electronic trans. I dont know. I couldnt tell you if the tranny would shift correctly with the engine not being injected. As for a non electric trans and an injected motor, you can do that. The best thing is to get a computer for the injected motor with a manual tranny, if you want to use the 77 trans behind the magnum motor.
