how to spend $500
Old Jan 30, 2006 | 03:57 PM
xxelfxx's Avatar
xxelfxx
Default how to spend $500
i have a 94 dokatoa 5.2 stock i am gonna have an extra 500 to spend on it what would you get and how much hp will it give me. thanks
Old Jan 30, 2006 | 10:35 PM
badassxr50r's Avatar
badassxr50r
Default RE: how to spend $500
um try and get headers and exhaust that would be my guess maybe an intake i dunno
Old Jan 30, 2006 | 11:50 PM
xxelfxx's Avatar
xxelfxx
I was thinkin about headers and pulleyes wat exhaust system do u recomend
Old Jan 31, 2006 | 06:31 AM
badassxr50r
um i would get any big name company exhaust like flowmaster, magnaflow, etc... but u could also just have a custom exhaust done too from a shop around town try and make sure u get manderal (sp?) bend piping cuz crush bent is no as good...
Old Feb 1, 2006 | 06:47 PM
Sneezer's Avatar
Sneezer
See if you can get a deal on a used Mopar PCM. I picked my last two up for $50 and $100 each. Get a TB from a junkyard, clean it up and port it yourself. Get a K&N drop in air filter and remove the weather plate behind the grille that partially blocks the air intake tube. Relocate your IAT sensor to the intake tube. Get a 3" single exhaust fitted. Magnaflow or Flowmaster mufflers work well. High flow cat if you need to replace your cat and are in an emissions testing state. Get a junkyard fan out of a Ford Contour/Mercury Mystique. It is a dual fan unit that is slim enough to work in our trucks. Ditch the stock clutch fan and wire up the electric in its place. UD pulleys do not give much gains. I would do them last over anything else. Also keep an eye out for any used camshafts. Might get a good deal on a Mopar RT cam, or even a KRC 210x or Comp Cams 604 cam.
You might be able to get most of that done for $500. Exhaust is going to be the most expensive part though.
