tranny question
Old Feb 14, 2006 | 09:09 PM
littlered91's Avatar
littlered91
Default tranny question
the plate on the side of my tranny says that it is a New Process A535. This tranny is not even an option in the Haynes manual for these trucks. Its a 2.5 4banger with a 5-speed. What does all this mean!!? Any help is great. Thanks.
Old Feb 15, 2006 | 02:50 AM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: tranny question
A535 is the Chrysler style trans that it is
Like the V6 one is a A500 and teh V8 one is a A518
Old Feb 15, 2006 | 10:30 AM
littlered91
what oil does this take. it needs changing. thanks.
Old Feb 15, 2006 | 11:45 AM
JDakota92's Avatar
JDakota92
ATF+3 is the OEM type, but ATF+4 is better and is only available from the dealer. ATF+3 is available at most parts stores.
Old Feb 15, 2006 | 07:32 PM
littlered91
will it still use ATF even though its a manual
Old Feb 16, 2006 | 01:30 AM
360DakotaPwr
Thats what I was thinking. Probably not. It will either take gear oil or a standard grade of engine oil. Look in the owners manual, call the dealer, or there should be a tag on the side of the trans telling you what to put i it.
Old Feb 17, 2006 | 12:33 PM
postrucks's Avatar
postrucks
If it is a A535 or also called a NP2500 it will have a parting line in the middle of the tranny also will have a inspection cover on top of the tranny fwd of the gear shifter. Go to Mack transmissions online and they have pictures. also its suppose to have 10-30 engine oil in the tranny.
