Hot/cold running problem
Old Feb 16, 2006 | 12:24 PM
moose482's Avatar
moose482
Default Hot/cold running problem
Have a 94 Dakota V6 that runs like a dog when it is cold outside, can't even drive it it is so rough. When the temp is warmer it runs fine. Any ideas? Thanks.
Old Feb 27, 2006 | 10:11 PM
28this's Avatar
28this
Default RE: Hot/cold running problem
Check your map and O2 sensors. Sounds like you got a bad one. If not, your cpu may be going on the fritz.
Old Feb 28, 2006 | 01:55 AM
360DakotaPwr's Avatar
360DakotaPwr
If its temp related, make sure the inlet air temp sensor is not cover with crap.
Old Mar 3, 2006 | 11:32 PM
bdodge_445's Avatar
bdodge_445
My truck did the same thing, check your choke to see if thats stuck.
