1993 Dakota Tire Size
Old Feb 17, 2006 | 01:00 PM
snickram's Avatar
snickram
Default 1993 Dakota Tire Size
I'm getting new tires and will probably go with 235/75R15 which is slightly taller and less expensive then the original size 235/70R15. Do you see any problem with this? Thanks..
Old Feb 17, 2006 | 10:18 PM
Sneezer's Avatar
Sneezer
Default RE: 1993 Dakota Tire Size
I have been told that the 235/75 is too tall and will rub, the 235/70 is a better fit. However, from what I have seen it looks like rubbing is limited to full lock or possibly on severe bumps when you have close to full compression on the front suspension. I currently have a set of mismatched tires on mine. 75s in the rear, 70s in the front. Haven't gotten around to replacing them with a matched set yet, but will happen soon I hope. For my driving which is just around town, I think the 75s would be fine, especially if it results in decent savings. I found the same thing when I was looking for tires last year. Bigger selection and cheaper tires in the 75 series.
Old Feb 17, 2006 | 11:20 PM
JDakota92's Avatar
JDakota92
I'm not sure about being in 2WD form, but my 4WD had 235/75R15's on it stock. I bumped them up to a 30" set with no rubbing problems at all.
Old Feb 18, 2006 | 02:59 AM
stantheman's Avatar
stantheman
the 75s might not rub too much, your speedo will prob be off about a mile or two.
Old Oct 10, 2006 | 11:11 PM
DukeSupes's Avatar
DukeSupes
I have had my 93 le 4x4 for less than a week now and love it. And I too have the 235/75/R15 and have experienced nothing but smooth handling and performance.
Old Oct 11, 2006 | 02:52 AM
jonnymagnum's Avatar
jonnymagnum
I had a set of 235/75r15's on my 88 2wd and they rubbed a lil bit when I turned but then I took a hammer to the bottom of the fender a lil bit and it never rubbed again. but I noticed a big difference in power and gas milage so I went back to a smaller tire.
________
Opium rehab advice
