Changing water pump on 94 dakota 318 v8 need help......
Old Apr 1, 2006 | 06:28 PM
94Dakota318's Avatar
94Dakota318
Default Changing water pump on 94 dakota 318 v8 need help......
i got the pump out..... I can not remove the fan from the pump??? what am im doing wrong
is the fan blade revers thread? everything just spins, what do i have to do to get it off..
Help needed quick.....
Old Apr 1, 2006 | 09:11 PM
stantheman's Avatar
stantheman
Default RE: Changing water pump on 94 dakota 318 v8 need help......
You actually shoulda taken the fan off before you took the pump off. With the pump pulley facing you the fan will need to turn to the left to come off. Clamp the pump and get ya a 36mm wrench and jab a flat blade screw driver behind the pulley between the pump and hit the wrench with a hammer. Alot easier on the vehicle though. Just got through doing mine today.
Old Apr 1, 2006 | 09:27 PM
94Dakota318
I got it off just finished.....
Thanks for your reply....
Def would have been easier in the truck.. but.. hey ya live and learn...
Old Apr 2, 2006 | 07:00 PM
stantheman's Avatar
stantheman
glad you got it off, now ya know. see ya
