low side retrofit adapter nipple 89 dakota v6 -- no luck!
Old Apr 9, 2006 | 07:27 PM
drussell4801's Avatar
drussell4801
Default low side retrofit adapter nipple 89 dakota v6 -- no luck!
Hello everyone, my first post, saying hi and asking for help with something.. Searched, and found nothing..
89 dodge dakota v6.
retrofitting a/c... Problem is I only found an adapter for high side. Tried every adapter at every auto parts store in town, none fit on my original low side fitting. Should be a standard fitting, and a standard retrofit adapter, but its NOT.
Any suggestions? thanks in advance...
-Dan
Old Apr 10, 2006 | 03:24 PM
bionic4.0's Avatar
bionic4.0
Default RE: low side retrofit adapter nipple 89 dakota v6 -- no luck!
take a pic and send it if you can i had this pro when i did mine and when i did my lebaron and i end up finding the part at auto zone but not for normal use
Old Apr 10, 2006 | 08:36 PM
drussell4801
thanks for the reply.. i don't have a camera to use, but I can probably borrow one..
Old Apr 13, 2006 | 11:19 AM
bionic4.0's Avatar
bionic4.0
i can tell you this on my dakota it was a std one from auto zone but it points straight out a the front of the engine so you have to shut off the engine and pass the hose under the belt then you can start and fill it with r134a
