ABS. Rear-Only, or All Wheel?
I was trying to find out how much new rotors would cost, and it is turning out to be a pretty penny, and I may not be able to get them right away.
But aparrently, it makes a difference in whether it has Rear-only ABS, or All-Wheel ABS.
How do I find this out?
My current rotors are rusting and if I will have to order new rotors, I want to be able to get them before anything bad happens to my brake system.
Thanks
Thanks
hey i was buying a front wheel bearing for truck and I thought it had 4 wheel abs. they told me there should a wire coming out the back of the hub. so I looked on mine and it didnt have any wire, so it only ended up being $310 instead of $390. they said most of the dakotas have only 2 wheel abs. parts are a lot cheaper if you dont have abs. mine is a 4x4 so the only diference is my wheel bearing is a sealed unit and it comes with the whole hub. is your 2wd or 4x4 either way there should be a wire coming out of the back if it has front abs.
________
LovelyWendie99
________
LovelyWendie99
