92 dak 34 fault code
Old Jul 20, 2006 | 04:14 AM
spankyj's Avatar
spankyj
Default 92 dak 34 fault code
I have a 92 Dakota with 294,000 miles the check engine light came on so I ran the fault codes and got a 34 which says speed control vacuum or vent control solenoid circuit(s) . I read half my haynes manual and still not to clear on what it is or where it is . Can anyone help ? Thanks
Old Jul 22, 2006 | 10:13 AM
dodgerules86's Avatar
dodgerules86
Default RE: 92 dak 34 fault code
What they Haynes manual says for the code is correct.
Provided is some wiring diagrams. Note the areas I point out with the red boxes in the 3rd picture. These are the exact circuits the code is for.
Post back with results, or if you need more help.
[IMG]local://upfiles/948/80601FD076114FF7A646C56E12CFD51C.jpg[/IMG]
[IMG]local://upfiles/948/B670F504C0F44B8A9DA990E1C4DE8CFF.jpg[/IMG]
[IMG]local://upfiles/948/44AD2BEC5BAD47BDA34986277667332C.jpg[/IMG]
