lifter noise on 3.9
i have a slight lifter noise on my 89 3.9. is there an additive that i could be adding to the oil, or maybe switch to a synthetic oil that would reduce this. i currently run the standard valvolene oil
I've used marvel mystery oil in my crank on my 2000 ram 5.9 motor and the noise went away...
some other interesting MMO reading...
https://dodgeforum.com/m_479194/tm.htm
I added lucas engine oil stabilizer to my crankcase in the talon and the lifter tick that plaged my dohc 2.0l went away. I also added some to my 3.9 in my dak and it quieted that down a bit too. It also had a lifter ticking. Not bad tho, but enough I could hear it when it idled. It seems to run a tad bit smoother too.
I use lucas too. in my 88 dakota 3.9 I had a huge lifter noise, so I dumped a bottle of lucas in it and the noise went away.
and if you lend your truck out to anyone make sure they KNOW what the oil light means![:@]
________
No2 Vaporizer
________
No2 Vaporizer
ORIGINAL: jonnymagnum
