Heater not blowing hot
Old Sep 5, 2006 | 12:37 AM
Bad96_3.9's Avatar
Bad96_3.9
Default Heater not blowing hot
Last winter my heater started to got out on me. I was thinking that it may be the heater core that is bad in it. All of the cooling system is new like the radatior, thermostat, water pump, ect... I have looked at my service manual and realized that it would take some work to change the heater core so i want to get a second opinion on the matter to see if that is it. I was wondering if anyone else has had this problem and if the new core fixed it. Thanks.
Old Sep 5, 2006 | 12:56 AM
gb6491's Avatar
gb6491
Default RE: Heater not blowing hot
This is a "back flush" procedure for heater cores posted on another forum that had many favorable results:
"Dan's original post
Here is an answer to the original question about the posters heater core. It is plugged. I had the same exact problem. I had flushed out my coolant system several times, but still no real heat coming from the heater. I then finally thought about it and realized the the convential way of flushing out a coolant system does not really flush out the heater core. The problem is that when you flush the coolant system out you normally connect the flushing water to the inlet side of the heater core hose and then backflush the system out through the radiator cap. This works fine for the engine and the radiator, but does not backflush the heater core. But for less than 99 cents and about 15 minutes you can easily backflush your heater core yourself. There was a suggestion on an earlier post to just reverse your inlet and outlet hose on the heater core and that would backflush it. This is true, but the gunk that is clogging up the heater core will just get flushed into you engine and will probably end up right back in your heater core. What you have to do is get a 5/8 inch female garden hose adapter. This can be purchased at just about any hardware store. Make sure it is the kind that slips inside the garden hose. Then with the engine cool you need to disconnect the outlet hose of the heater core from the engine. You need to do this at the water pump connection, which should be on the driver's side of the engine. Then insert the garden hose adapter into the end of the hose. Then disconnect the heater core inlet hose from the engine connection. On my Dakota this is easily done at the splice that is on the passengers side of the engine. This splice is where you normally connect to flush out the coolant system. Then hook a garden hose up to the outlet hose and turn on the water. Have someone help you turn on and off the water as you flush out the heater core. Try and collect atleast the first 2 gallons of stuff you flush out and dispose of this according to your local laws. After the first 2 gallons all you should get out of your heater core is dirty water. This should be ok to just dump on the ground but make sure first. You will probably have to flush the core for a good 5 minutes to fully clean it out. Then reconnect your heater hoses as they were and enjoy the heat. "
Regards,
Greg
