vacuum diagram info
Old Sep 17, 2006 | 01:51 PM
ib4shore's Avatar
ib4shore
Default vacuum diagram info
I have a 92 Dakota 4wd. I was wondering if anyone could point me in the right direction to find a vacuum diagram? I have a couple of broken lines that I don't know where to hook up. Also I am having a problem with my transfer case not engaging and believe that it may be vacuum related. Any info will be greatly appreciated.
Old Sep 17, 2006 | 11:05 PM
dodgerules86's Avatar
dodgerules86
Default RE: vacuum diagram info
Here is a vacuum diagram from my '96 Dakota, should be similar.
[IMG]local://upfiles/948/E354A9EF2BCF4916903C197B7CC5D13E.jpg[/IMG]
Old Sep 18, 2006 | 11:25 PM
ib4shore's Avatar
ib4shore
Thanks, I looked on the auto zone website and it gave pics of the under hood stickers. I had some extra lines when I put my motor back in after a failed submarine attempt 3 lines came from the transfer case, there must be a blockage of sorts because my 4wd was not engaging. So I hooked the vacuum up direct and the hubs engaged. Works fine now. I have a 92 with a 5.2 liter V8. I was worried because I had just replaced the transfer case last winter and figured that it went belly up. But now I am happy cause it works.
Old Sep 20, 2006 | 11:42 PM
erock92kota's Avatar
erock92kota
I never realized that autozone had vacuum diagrams and alot of other info I was looking for. You helped me out without even trying on this one. Thanks. Dodgerules gave me a vacuum diagram that had me in the ballpark, but I did have some of them wrong yet since it was close, yet not the same. But now its all good under my hood.
