Where Is The Ignition Relay??
I'm going to try a new ignition relay and see if it fixes my problem (truck wont start when cold w/out waiting 1-2 hours w/ key turned forward, I have a thread somewhere around here).
WHERE is the ignition relay located???
Pictures would be awesome!
Thanks guys! I REALLY need to get this taken care of asap.
ignition relay is on the fenderwell drivers side by the firewall without knowing what year your truck is I cant give you a part # however if you go to www.autozone.com and check repair then component locations type in relay and then look for ignition relay it will give you a location and possibly a part # the relay for my 87 dak is GP SORENSON EL500
