Need More Cold Air
Old Oct 24, 2006 | 08:20 PM
slamman17543's Avatar
slamman17543
Default Need More Cold Air
ive got about 56K miles on my 94. its no joke. runs like a champ. its just not perforing like i want. i want to really CRANK some more power. has anybody found a good cole air intake. also where is a good place to pick up a 360 and does it bolt striaght up. any other suggestions would be great.
Old Oct 24, 2006 | 11:10 PM
dodgedakotacrazy's Avatar
dodgedakotacrazy
Default RE: Need More Cold Air
whast the motor you have right now. mopar has crate motors....also a 360 will bolt up to a 318 tranny but the Tq will need changed as the motor mounts?? i think ..i know the older 318 and 360s had different pass. motor mounts not sure on the newer ones..the torque converter needs changed because the 318 is internally balanced and the 360 is externally. b&m makes weld on weights to balance the flywheel. if its a v6 i'm not sure if the tranny will bolt up.
