clutch master cylinder replacement PLEASE HELP
Old Nov 5, 2006 | 04:49 PM
19dakota94's Avatar
19dakota94
Default clutch master cylinder replacement PLEASE HELP
Hey GUYS...heres my problem...my clutch pedal has been progressively getting harder to push...so after a little investigation i figured out that my master cylinder for the clutch is going bad...it is leaking into the inside of the truck...a weird spot i know...well i went to the junk yard to see how they are put together, between haynes book and junk yard playing around i found out that i cant disconnect the line from the master to the slave...unless there is a way i dont know about...they sell the master seperatly and was going to just replace that....does anyone have any idea how i can just replace the master? or what i can do to disconnect the line from the master? I have a 94 with a 3.9 extg cab...any help would be much appreciated!! Thanks in advance everyone....
Old Nov 6, 2006 | 12:57 AM
dodgerules86's Avatar
dodgerules86
Default RE: clutch master cylinder replacement PLEASE HELP
According to the book, the clutch master cylinder, remote reservoir, slave cylinder, and lines are all one big happy assembly.
[IMG]local://upfiles/948/06FCCC56BF4D4E878756AF4D3990ABB6.jpg[/IMG]
