temp gauge
Old Dec 6, 2006 | 12:14 AM
Drako1313's Avatar
Drako1313
Default temp gauge
ok i dont get it my temp gauge stoped working but it ohms out fine and all the wires are connected. I stoped to get gas and when i started it back up it hit the bottem and stayed there any one have a clue whats going on i cant fine anything saying theres a fuse for it so i'm kind of stumped
Old Dec 6, 2006 | 12:16 AM
Drako1313's Avatar
Drako1313
Default RE: temp gauge
sorry forgot 2 add 93 5 speed 3.9L 2x4 standered i'm thinking of rewire it but i dont want to tear the dash out
Old Dec 6, 2006 | 12:28 AM
jonnymagnum's Avatar
jonnymagnum
mine quit workin a while ago too. and I still havent figured it out.
________
Zoloft Prilosec Nexium
Old Dec 6, 2006 | 01:55 AM
Mr_Shorty's Avatar
Mr_Shorty
Have you checked the sending unit on the motor? Also, When I was retracing the wiring in mine, I found the block connection from under the hood into the firewall was WAY corroded... I used some CRC electrical cleaner and then greased it with di-electric grease. Also, someone told me that the connections going into the cluster need to be unplugged and replugged to help the connection.
Later Daze,
Shorty
Old Dec 6, 2006 | 02:00 AM
jonnymagnum
I've tried to put a new coolant tem sensor in, but mine still doesnt work. I dont really care. as long as I get heat I'm happy.
________
Zoloft Lawsuit
Old Dec 6, 2006 | 04:17 AM
dodgerules86's Avatar
dodgerules86
Remember, the sensor that controls the gauge is to the right (pass. side) of the upper hose. It has a single-wire connector.
Old Dec 6, 2006 | 04:36 PM
jonnymagnum
ya, the one on the front of the motor by the top rad hose is the one I replaced. do we have 2 of them?
________
Masturbation *****
