POSI?
Old Dec 13, 2006 | 02:54 PM
DukeSupes's Avatar
DukeSupes
Default POSI?
Did they put POSI rear ends on any 93 dakotas?
Old Dec 13, 2006 | 03:20 PM
jonnymagnum's Avatar
jonnymagnum
Default Re: Posi?
im pretty sure they did. one way to tell if your truck has posi is to jack up the rearend and put in neutral. then spin one tire, and if the other one spins the same direction, then you have posi. if it spind the opposite direction then you have an open diff.
or another way to tell is to do a burnout! [sm=gears.gif]
________
Lovely Wendie
Old Dec 13, 2006 | 11:05 PM
dodgedakotacrazy's Avatar
dodgedakotacrazy
Default RE: POSI?
yes they did. also you could buy a posi fairly resonable.. I have one that i might sell if i can find it and if i don't think i'll use it. it has surface rust but its good.
Old Dec 13, 2006 | 11:27 PM
dodgerules86's Avatar
dodgerules86
Default RE: POSI?
As dodgedakotacrazy said, they did. I own one.
If your truck will do one... mine won't at the time. (Well, going forward at least)
Old Dec 13, 2006 | 11:39 PM
jonnymagnum
Default Re: Posi?
ORIGINAL: dodgerules86
mines a one wheel wonder and since I have 360lbs in the box for the winter she wont spin at all either. I wish I never blew my old rearend apart. it was posi and it would spin all the time. now this one wheel wonder it will spin when I leave a stop light when I didnt have the weight in it.
________
Sell Vaporizers
Old Dec 14, 2006 | 12:22 AM
Mr_Shorty's Avatar
Mr_Shorty
Default RE: POSI?
Mine wont spin em in forward, but spins both in reverse... Mine is more of an issue that I don't give it enought fuel... It flops around like a dieing chicken if I try, because someone cut V notches in the motor mounts to make installing the motor back in a lot easier... and they also never bothered to tighten the bolts down. So I get to fix that this weekend.
Later Daze,
Shorty
Old Dec 14, 2006 | 05:17 AM
moparmanewulm's Avatar
moparmanewulm
Default RE: POSI?
i have a 93 with a 3.9 and its limited slip. but other wise is acts like posi
Old Feb 20, 2007 | 03:51 PM
DukeSupes's Avatar
DukeSupes
Default RE: POSI?
Well I did my first burnout (totally by accident) in forward I left two beautiful marks on the pavement. So I guess I have one of the good rearends :P
Old Feb 22, 2007 | 09:48 PM
dodger8691's Avatar
dodger8691
Default RE: POSI?
my 91 has posi becausr there are always 2 nice and dark stripps after the smoke show so if the 91 has it the 93 should
Old Feb 27, 2007 | 12:56 AM
Bad96_3.9's Avatar
Bad96_3.9
Default RE: POSI?
ORIGINAL: jonnymagnum
<<<<<<<I can do them!!!
