Making headlights new again
Old Dec 28, 2006 | 12:36 AM
Prangleys 95 Dak's Avatar
Prangleys 95 Dak
Default Making headlights new again
I have the newer light system with halogens. My problem is, the outer cover for my headlightsare yellowing. The orange turn signals are still nice. I was thinking I might trytake the covers off and dipping them in a dilluted muriatic acid solution for like 30 seconds then rinsing to see if it would take the yellow out and make them look new or newer. Good idea or bad???
Old Dec 28, 2006 | 12:55 AM
Moven Up's Avatar
Moven Up
Junior Member
Default RE: Making headlights new again
Sometimes you can polish the outer layer and bring them back to life. Try starting with a nice paste car wax and then follow up with some plastic polish. Otherwise you will have to replace them.
Old Dec 28, 2006 | 01:33 AM
jonnymagnum's Avatar
jonnymagnum
some people even use some fine sandpaper, like 1000+. and just wet sand it.
I always see comercials about someting called flitz it. its suposed to clean headlights and that stuff too. but I dont know how good it would be.
Old Dec 28, 2006 | 05:11 AM
BAnders's Avatar
BAnders
i bought this plastic cleaner and polish from car quest, it worked pretty good
Old Dec 28, 2006 | 03:49 PM
Chris's Avatar
Chris
These are all temporary solutions. To get the look of new headlights, you will need to get new headlights.
Old Dec 30, 2006 | 03:40 PM
CADster's Avatar
CADster
^ true.
a mothers powerball and some plasticX polish will do wonders. it will also last a long time.
(i did my lights last year and they still look great)
Old Dec 31, 2006 | 05:37 PM
89 dakota's Avatar
89 dakota
Check this out!
https://dodgeforum.com/m_462669/mpag.../tm.htm#544230
Old Dec 31, 2006 | 06:01 PM
dodgerules86's Avatar
dodgerules86
ORIGINAL: virused
These headlights are not cheap (~$160 from the dealer)... buying new ones is pretty much a rip off considering their made of all plastic (which is why you have this problem).
And than, you will have the problem come back with the new ones, granted, it will take about the same number of years.
The polishing compound might require more frequent maintenance, but its a heck of a lot cheaper... unless you want to drop $320 on headlight assemblies.
Old Dec 31, 2006 | 10:37 PM
rhad's Avatar
rhad
i bought a NEW PAIR on ebay for $56.95
Old Jan 1, 2007 | 06:01 PM
Prangleys 95 Dak
That is a good ebay buy! Thanks for the feedback. Dodge Boys rule!
