No Heat
if you feel both of the heater core lines, they should both be hot.
also when you changed the heatercore, did you make sure you put the blend doors on in the right place and hook up all the cables. cause maybe a blend door is saying stuck open and it's just pulling in cold air.
Found the problem. The heater hose coming from the block had a kink in it down by the block and I didn't see it right away. The hose was a little short but I thought it would work. Guess I was wrong! Thanks for all the help.
