was thinking the same thing will have to do the measurements but i think if you pull the liner out you should be able to fab a decent box in there fiberglass would be best to conform to the shape but a good band saw would work on mdf just make sure you pad the bottom since it wont have the rubber liner ill try to measure mine tonight and see what i can come up with. would recomend steel grilles for the speakers since they will face up and well things like to fall down
