crank sensor
Old Feb 10, 2007 | 01:45 AM
lesimon's Avatar
lesimon
Default crank sensor
92' Dakota 5.2.. Has anyone ever had problems with their crank sensor? if so what sort of symptoms did this cause?
Old Feb 10, 2007 | 07:34 AM
Chump's Avatar
Chump
Default RE: crank sensor
http://dodgeram.info/tsb/1992/18-04-92.htm
Old Feb 11, 2007 | 07:58 PM
punkrock87's Avatar
punkrock87
I have a 93 Dakota 5.2 that had the crank sensor go out. I was driving and the engine cut out and it wouldn't start up again. I tried to get it to start a few weeks later and it would drive without problem. The second time it cut out I took it and got the sensor replaced for only 450$. Quick cheap fix and I haven't had a problem since.
Old Feb 12, 2007 | 12:50 AM
injmopar's Avatar
injmopar
$450 !! How much was the sensor it self.
Old Feb 12, 2007 | 10:29 PM
Dannyboy07's Avatar
Dannyboy07
the crank sensor for that truckis about $100 at the dealer ship probably cheaper at your local parts store.
Old Feb 13, 2007 | 12:47 AM
injmopar's Avatar
injmopar
I didn't want to buy one .I was just trying to figure out what the dealer charged to remove and replace two bolts.
Old Feb 14, 2007 | 12:17 PM
DukeSupes's Avatar
DukeSupes
Oh yeah thats no joke, dealerships will do anything to mark up the price. Including find other things wrong with your car or truck. A friend (that used to work at one) told me that the mechanics in the dealership get a commission off of any additional problems they find while doing oil changes and routine maintenance. I guess its good that they are trying to look out for you like that, but on the same token you cant tell me that a money hungry jerk wouldnt say that something is going out and then get the commission and probably not replace the part.
