check engine light/overcharging
Old Feb 20, 2007 | 06:59 AM
counselor dude's Avatar
counselor dude
Junior Member
Default check engine light/overcharging
I almost am ready to give up. Its not the new alternators(3);its not the battery (2).Some say its the emission control(oxygen sensor?) its not the computer(newer one installed) so what is it? The light goes on after a couple of minutes driving. It goes on when the battery gauge goes to the end of the bracket. The tester shows the batterey cycles from 13.8 to 16 volts.The alternators are from Advance.Some say you have to buy 5 to get one good one? help122,000 miles
Old Feb 20, 2007 | 11:13 AM
dodgerules86's Avatar
dodgerules86
Default RE: check engine light/overcharging
Welcome to the forum!
As far as the check engine light, go here to find out how to pull the codes.
This may be able to help some in finding out the problem.
Old Feb 23, 2007 | 01:43 AM
counselor dude
Junior Member
I can now answer my own problem so other dakota owners will learn. It was the the junk yard computer that i purchased for $20. I assumed my computer was bad...it was. But if I would of purchased a new or reman computer from napa the problem would be solved. Now since its at the dealer,it will cost $1000. That includes a $550 computer and almost three hours of diagnostic charges. If i would of bought a battery,an alternator and a computer ,I would of found the problem and saved money.
Old Feb 25, 2007 | 11:05 PM
Ryathis's Avatar
Ryathis
Sorry to hear the stealership has got ya by the you know what. but atleast its fixed!
