ASD
Old Mar 8, 2007 | 09:43 PM
Curlley 92's Avatar
Curlley 92
Default ASD
1992 V6 ASD fuse blows immediately after engine starts, any ideas? what triggers the ASD relay?
Old Mar 8, 2007 | 09:51 PM
dodgerules86's Avatar
dodgerules86
Default RE: ASD
Welcome to the forum.
The ASD relay is used to power the ignition coil, fuel injectors, oxygen sensors, and the fuel pump.
The ASD relay is "triggered" when the ignition switch is on, and the PCM provides a ground. Of course, the fuse would blow because one of the above items is drawing too much current or there is a short in the wiring.
Old Mar 9, 2007 | 12:07 PM
Dan G's Avatar
Dan G
Default RE: ASD
Fuel pump most probably
Old Mar 13, 2007 | 08:05 PM
Curlley 92's Avatar
Curlley 92
Default RE: ASD
Thanks for the help! After further troubleshooting, found the O2 sensor wires grounded.
