Piston to cylinder wall clearance
Old Mar 13, 2007 | 12:08 AM
bobu80's Avatar
bobu80
Default Piston to cylinder wall clearance
Does anyone know the specs for the pistion to cylinder clearance in the '92 dakota 2.5L?
Old Mar 15, 2007 | 12:20 AM
virginiaswampdog's Avatar
virginiaswampdog
Default RE: Piston to cylinder wall clearance
The Haynes book that I have has a piston diameter of 3.443 in to3.445 in with a cilinder diameter of 3.44 in nominal . I thank that they may have those figures backwards ??? If so that would be .003 to .005 clearince. Does that make sence to you ?
