done
Old Mar 26, 2007 | 09:49 PM
rhick426's Avatar
rhick426
Default done
done
Old Mar 27, 2007 | 02:22 AM
injmopar's Avatar
injmopar
Default RE: ECM for 1991 5.2L
You could use a regulator from a late 80's dodge. I have a 88 with a 95 alternater hooked to the 88 regulator.It works just fine
Old Mar 27, 2007 | 03:38 AM
91dodgedakota's Avatar
91dodgedakota
yes there is a fix. first off never pay 400 for another ecm. secondly like the last user said use a external voltage regulator. i have the same excact truck with the same exact problem and thats what we did we rewired the alt to use a external voltage regulator that we mounted on the fire wall. granet it will still have a trouble code in the computer cause it thinks it isnt charging but it will work and will charge the battery if you need help let me know i can show you how it was done and what wires to use. you can also email me at 93explorer @ gmail DOT com.
Old Mar 27, 2007 | 05:12 AM
Ryathis's Avatar
Ryathis
How about if you put a resistor into series with the computer so it sees some resistance and thinks it is charging? Just a thought.
Never ran an external voltage regulator with a computer with a gasser, but did it on my old 1992 dodge d250 w/ a cummins in it. It also through a check engine light for the same reason, always wondered if the above solution would work.
