92 dakota stalls in reverse and while stopping
Old Oct 12, 2009 | 07:43 PM
towmowman's Avatar
towmowman
Default 92 dakota stalls in reverse and while stopping
I have a 92 dakota 3.9 v-6 2wd with just over 200,000 mls,recently it has started to idel low and it stalls in reverse and when coming to a complete stop,also i bought a new battery and for it and just sitting the battery has run down any ideas what the problem could be?
Old Oct 12, 2009 | 08:25 PM
woodbutcher5691's Avatar
woodbutcher5691
Same thing with my '94. Couple months later, I was tranny shopping. It was toasted.
Old Oct 12, 2009 | 08:50 PM
95_318SLT's Avatar
95_318SLT
Do you think it's transmission related like woodbutcher suggested, or do you think it's engine related? A good way to find out is when its about to stall like you mentioned, pop in into neutral and see if it continues to stall. If popping it into neutral stops it from stalling, I agree with woodbutcher. If not, my first guess is a bad IAC.
200,000 miles is a lot of its the original tranny. They usually last 150,000-180,000 miles.
Old Oct 12, 2009 | 09:10 PM
woodbutcher5691
^^^ Yea mine had 260,000 +/_ miles. Guess I got a good deal on that one?
Old Oct 12, 2009 | 09:25 PM
95_318SLT's Avatar
95_318SLT
Wow, thats the most miles I've heard of yet on a dodge automatic transmission. You either got really lucky or did something right to take care of it!
Old Oct 13, 2009 | 07:34 PM
towmowman's Avatar
towmowman
changed fluid and filter every 28,000. If I hold the brake and gas at the same time it won't stall.So you think its the IAC?
Old Oct 13, 2009 | 09:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the IAC is a common problem with these engines. Replace it is the best thing to do.
Old Oct 14, 2009 | 12:39 AM
TheLoBO's Avatar
TheLoBO
Mine blowed at 178000 miles more or less, I thank god I wasnt running cuz it totally blowed in a very crowded avenue I had around 300 kilos on it. It cost me around 700 dollars to fix it, and in a month Im going to replace the fluid and filter since I had to change the turbine and other "hard" pieces. Jesus.
Old Oct 14, 2009 | 08:43 AM
pashadowops's Avatar
pashadowops
Great......mine just broke 200k....I guess I should think about servicing it then huh?
Old Oct 14, 2009 | 05:32 PM
vastolordcj's Avatar
vastolordcj
most likely a dumb question, but what is IAC?
