newer electronics for the old dog.
Old Apr 7, 2011 | 08:15 PM
capricorn's Avatar
capricorn
New Member
Default newer electronics for the old dog.
Hi all; I really need some advise. I have a 92, 5.2, with auto trans and want to pick up the pace a little. What I have in mind is to drop in a 5.9 with after market aluminum heads, mild cam, still street friendly with 87 octane because it's a daily driver. I'm afraid if I spend the bucks to build this and drop it in, my current ECM won't do the job. I do not want to go with a carb. I want SFI, which I'm aware I do not have now, so I'm considering the possibilities of going to OBD2 that can be reflashed to my needs, so I've heard???
What is my best, (and least expensive), option:
1: Buy a complete full size Ram donor truck and pull the entire harness, engine, transmission, (or will my current tranny do), and try to adapt it to my Dakota? I don't know if the fuel pumps are comparable, I'm running no cat., so two 02 sensors are required? The speedometer on OBD2 are electronic so will a speed sensor running off the cable be ok?
2: How about using my existing harness and finding a pin out diagram for each controller and then overlay or eliminate any wiring that is required? Will a reflash get rid of the need for a #2 O2 senor?
3: This is impossible and I should just rebuild my 200k+ mile 5.2 engine with the aluminum heads and an RS cam and be satisfied? I'm even considering a 5.9 stroke crank, (which would make it a 344ci), but fear that will throw off the electronic timing.?
JUST DON'T HAVE THE EXTRA $$$BUCKS$$$ TO THROW AWAY!!!
Any experienced advise will be greatly appreciated. Thanks
Old Apr 7, 2011 | 09:00 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If all your doing is "5.9 with after market aluminum heads, mild cam, still street friendly with 87 octane" Then you don't need a custom tune. And all your stock electronics will work. Only thing is get the 5.9 injectors.
The Mopar Performance Computer for a Ram 94-95 5.9 will be enough. That is what I have to run my 5.9 mild upgrades.
The stock transmission Can handle that power, as long as it is running good now.
If you go into a stroker kit or supercharger or something with LARGE power increase you may want to look into tuning and a stronger internal parts for the transmission. Or a race transmission from http://www.phoenixtrans.com
You can get custom flashing on our OBD1 computer at http://www.bgperformancepcm.com/#magnum But like I said mild build like you mentioned doesn't need it and Mopar High performance Computer is more than enough. You can get it from www.summitracing.com
Old Apr 8, 2011 | 08:22 PM
capricorn's Avatar
capricorn
New Member
Default Thanks 4x4
Your info is invaluable! I still have some questions for you but had a really long day so I'll hit you up again.
