5.9 conversion
Old Sep 8, 2011 | 08:24 PM
JMTiedemann's Avatar
JMTiedemann
Default 5.9 conversion
I was talking to the guys at the shop that i take my truck to, they have adviced me to get a higher output fuel pump. apparently in 94 the 318s had at most 44psi pumps, they said that my 99 360 should have at the very minumum 44 psi. i assume my pump isnt putting out 44psi anymore, if it ever did.
is this statement true? should i be looking for another pump?
do they make one for my gas tank?
Old Sep 8, 2011 | 10:46 PM
Hahns5.2's Avatar
Hahns5.2
It's not the pump that makes more pressure, it's the regulator. It's hard to know what needs to be done without a wideband O2 to tell you. If you run a 94-95 5.9 PCM with the 94-95 (5.2 and 5.9 should be the same) injectors it should be fine.
Old Sep 9, 2011 | 12:16 AM
JMTiedemann
thanks for the information.
on a different note how do you get a picture to show up in your messages?
Old Sep 9, 2011 | 03:07 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Here are fuel pressure ratings.
1993 Dodge Dakota Manual 31psi, 39 with no vacuum.
1995 Dodge Dakota Manual (35-45 psi) at idle.
1995 Dodge Ram Manual (35-45 psi)
1996 Dodge Dakota Manual (49.2 psi ± 5 psi) at idle.
1996 Dodge Ram Manual (49.2 psi ± 5 psi).
2001 Dodge Ram Manual (49.2 psi ± 5 psi) at idle.
2001 Dodge Dakota Manual (49.2 psi ± 5 psi) at idle.
Just to throw it out there here are some injector flow rates.
Engine Years Flow rate in lb/hr
Neon ( All) 23.9
2.5 Magnum 91-95 17.4
2.5 Magnum 96-01 23.2
4.0 Jeep 91-95 21.4 (Equivalent to Lucas 5207013 )
4.0 Jeep 96-01 23.2 (Equivalent to Lucas 5208005 )
5.2 Magnum 92-95 18.2
5.2 Magnum 96-01 23.2
5.9 Magnum 93-95 24.5
5.9 Magnum 96-01 23.2 (Seimens/Chrysler P/N 53030778)
Here is a great site to look up fuel injector part numbers and applications. http://www.fuelinjector.citymaker.com/contact.html
Old Sep 11, 2011 | 10:15 PM
JMTiedemann
thanks guy, thats lots of usefull information, and i just watched your newist vids on youtube, good lookin truck i wish i could do a SAS. maybe in the future. i also have to figure out how to post pictures and junk on here so i can show off "little miss dakota" (its actually known by that name around my town :-/)
Old Sep 12, 2011 | 01:43 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Thanks! I will be posting them up on my thread soon.
As for how to upload picture or videos here is a quick write up I did on it.
To upload pictures.
You can create a photo album on this site, Go to "User CP" (Control panel). Near the top of each page in the black strip.
Or you can do a 3rd party website like www.photobucket.com or www.tinypic.com and use the photo link that uses the [IMG] tags.
Or upload it to the post by going to the "Go Advance" post tab next to "post reply" at the bottom then to "Manage Attachments" near the bottom. Then "Browse". Find th picture on your computer files. Then Upload.
To upload videos create a www.Youtube.com account and upload, or use www.photobucket.com Then just copy and paste the video link.
Old Sep 12, 2011 | 07:31 PM
JMTiedemann
thanks, i cant figure the thread one out, my computer didnt like the steps. BUT i have the beginning of an album, its called my dakota build, check it out!
Old Sep 13, 2011 | 02:44 AM
Crazy4x4RT's Avatar
Crazy4x4RT
My guess is you reached your limit. I think there is a limit depending on how many posts you post up, to keep spammers out.
My best suggestion is start a www.photobucket.com account. It is free.
I love the winch bumper! Looks bad A$$!
