from 318 to 360?
Old Dec 29, 2003 | 03:52 PM
operations's Avatar
operations
Default from 318 to 360?
Hope some of you guys can help.</P>
I have a 99 4x4 Durango wit the 318, a real winnie in the power topic.</P>
It's getting close to 100K, </P>
That said, Dodge makes a 360 crate engine as a replacement for 93 and up Magnum FI, with more HP then the orginal 360 came with. </P>
What problems would I face changing to this engine, would the fuil sysem supply enough?</P>
Can these be Dyno tuined buy someone to reprogram the PCM?</P>
Thanks</P>
Old Dec 29, 2003 | 05:26 PM
dodgefreak's Avatar
dodgefreak
Well, if its the same block you should be able to get away with simply druping it in, pluging in the sensors...and taking off! </P>
</P>
The stock 318 and 360 were basicly the same motors!! They should have the same mounts and bolt patterns. As for the PCM your best bet is to get the one for the 360.</P>
