throwing 2 new codes...need help please
ok so, a few weeks ago i put up a post about my rango getting really really bad gas milage and was throwing 2 codes.....well its still getting really bad milage and now it has 2 different codes:
p1682: powertrain: driver 5 line 2 and p0171: powertrain: fuel trim system lean bank 1 can sumone tell me what these codes are and a possible way to fix them??? thanks |
RE: throwing 2 new codes...need help please
P1682 Charging System Voltage Too Low - your batterey died, or your alternator stopped working for a sec
as for the other, check your airfilter, and look/listen for vacuum leaks, or exhaust leaks in the drivers side manifold before the o2 sensor, also replace your fuel filter, may not be that bad but hey a clean filters always good also, disconnect battery ground, and unplug the computer (box mounted next to filter housing) for 5 minutes, this will clear the codes and reset the comp if the P1682 code will not clear, its because it is a manfactuer code and will need to be cleared at a dealership [/align] |
i cleared the codes last nite from my laptop and a few minuites later they came back....but i will try again
i havent been able to locate any vaccum leaks...but the exhaust does leak, just not before the 02 sensors... i tried to get a new fuel filter a few weeks ago, but for sum reason autozone said i have to replace the whole fuel pump in order to do this.....though i thought there was one on the frame rail:eek: i think i might take it to the dealer and have a fuel system check done....hopefully they can tell me why the milage is so horrible thanks |
