Changed Rear Differential Fluid
Old Apr 25, 2007 | 04:34 PM
20durango00's Avatar
20durango00
Default Changed Rear Differential Fluid
I useda Mighty Vac to pump out the rear diff. fluid and it worked very well. Was very shocked to find the rear did not have a threaded plug for refill, it only has a rubber stopper on the panfor servicing. This is on a 2wd 2000 Durango, no leaks but that rubber stopper doesn't seem very substantial.
Old Apr 25, 2007 | 06:06 PM
chemoman's Avatar
chemoman
Default RE: Changed Rear Differential Fluid
I serviced mine and it has slow leaked since. Not enough to matter, but enought to discolor the rear end.
Did you do anything special to keep it from leaking?
Old Apr 25, 2007 | 07:22 PM
20durango00
I just cleaned the plug real good before putting it back in. If it eventually shows sign of leakage then I may put some silicone rtv around the lip of the plug.
Old Apr 26, 2007 | 02:06 AM
IndyDurango's Avatar
IndyDurango
Change the rear dif cover with one that has a thread plug. Very easy, looks better, cheap, and problem solved.
IndyDurango
Old Apr 30, 2007 | 08:27 PM
chemoman's Avatar
chemoman
ORIGINAL: IndyDurango
IndyDurango
Do these rear ends have a vent hole?
Old May 4, 2007 | 04:56 PM
Backcounty's Avatar
Backcounty
IndyDurango
Hi Indy, new to this forum. do any of the sponsors carry this type of cover?
