exhaust
Old May 21, 2007 | 10:36 PM
  #21
cesspool's Avatar
cesspool
Default RE: exhaust
and what about this cat:
140108007295
Old May 21, 2007 | 10:46 PM
  #22
cesspool's Avatar
cesspool
Default RE: exhaust
what about these headers:
170114166214 or
330121759566 or
200111035941I want to replace everything as far as the exhaust goes.
Old May 21, 2007 | 11:06 PM
  #23
Mean Green's Avatar
Mean Green
Default RE: exhaust
Yes it is after the cat so if you do want aftermarket you will have to get the cat as well. If I were you I would just use the stock pipes since they flow really well already and will not rot out for the life of the truck and why throw all that extra $ away on it just to get rid of the surface rust that isn't going any further.
As for the o2 sims I'm sure they would work fine I forgot about telling you about them.
Old May 21, 2007 | 11:49 PM
  #24
cesspool's Avatar
cesspool
Default RE: exhaust
ORIGINAL: Mean Green
So they could just take the old muffler/cat off and replace them only? I was unaware of that. I though things would have to be cut.
o2 sims? what is this?
Thanks!
Old May 22, 2007 | 02:51 AM
  #25
Mean Green's Avatar
Mean Green
Default RE: exhaust
Post #17 has a link for o2 sims they make the PCM think you are running clean. As long as you don't have a sniffer test then have at it.
A muffler shop would have to cut the muffler and cat off and weld new ones in and it might be smart for you to see how much it would cost to buy your muffler and cat from a shop than to just buy one from summit and pay labor out. I got mine from a shop here in Reno for $125 installed.
Old May 23, 2007 | 03:20 AM
  #26
orlandozfreak's Avatar
orlandozfreak
Default RE: exhaust
i still think i'm louder, the CBT2 doesn't really muffler as mush as even the pulses, it sounds like straight pipes
Old May 30, 2007 | 01:36 AM
  #27
Lil Red Mopar's Avatar
Lil Red Mopar
Default RE: exhaust
I just ordered a Flowmaster Force II Single 3 inch Rear Exit Aluminized Steel Cat-Back System With 3inch Stainless Tip, it ships on 6/3 , this coupled with the AEM BRUTE FORCE cold air intake with TB spacer I installed should add volume , if not I'll just put a FM outlaw series on it and watch the neighbors ears bleed !
Old May 30, 2007 | 02:18 PM
  #28
Kensai's Avatar
Kensai
Default RE: exhaust
Just curious, what equilivent model of flowmaster or mangaflow mufflers would give the same similar sound and decibels as the OEM muffler that is on the R/T? I want to change mine out and go with a split single in and dual out configurations. However, I do not want to advertise to everyone especially to the guys in blue to know where I am at when I stomp on the gas. But I do like to have the same similar sound as the OEM muffler that is on my R/T.
Old May 30, 2007 | 03:08 PM
  #29
Mean Green's Avatar
Mean Green
Default RE: exhaust
Ken I'd say probably a 50 series fm. hit up fm website and listen to the sound clips.
Old May 30, 2007 | 08:15 PM
  #30
cesspool's Avatar
cesspool
Default RE: exhaust
where can I get one of these? Are they direct replacements, i.e... no glithces with the cpu because it's aftermarket?
