Lift otpions
Old May 30, 2007 | 08:23 PM
cesspool's Avatar
cesspool
Default Lift otpions
I am replacing the shocks with bilsteins before long. I was pondering the idea of a small lift and would assume the time to do it would be when I replace the shocks. I want a small lift so I can put 35's on it next time I need tires. What is the most economical way to go. Nothing extravagant, but I also don't want the steering wheel to turn 12 turns to the left and half a trun to the right.....
Old May 31, 2007 | 12:02 AM
orlandozfreak's Avatar
orlandozfreak
Default RE: Lift otpions
i believe fabtech makes a 3" kit that should barely fit 35's, you could try the 3" lift with the 2" T/S lift, i'm pretty sure they can be done together
Old May 31, 2007 | 09:05 PM
deerang's Avatar
deerang
It will rub on hard turns and suspension compression/articulaiton.
