rear A/C
Old Jun 1, 2007 | 09:51 PM
cesspool's Avatar
cesspool
Default rear A/C
My rear A/C Has NO power t it at all. Not to long ago I had the heater core replaced and it hasn't worked ever since. I'm guessing a wire (ground maybe?) isn't hooked up. I had posted in a earlier thread:
https://dodgeforum.com/m_773637/tm.htm
But had little reply. Is there a seperate Relay for the rear A/C I could check first? If not, where is the best place to look, under the driverside dash? Passanger?
Any help would be greatly appreciated! I want to take apart as little of the dash as possible....
on a side note, I did find a screw on the floor board that goes into the dash assmebly somewhere.
Old Jun 1, 2007 | 11:39 PM
Mean Green's Avatar
Mean Green
Default RE: rear A/C
I would check all the ground wires. They should be painted green if I remember correctly. See if any of them are loose. I know of one on the drivers side firewall(or maybe I turned that into a ground for my cb sorry I don't remember).
