Transfer case
Old Jul 25, 2007 | 09:22 PM
Mean Green's Avatar
Mean Green
Default RE: Transfer case
Shift on the fly 2wd 4hi and 4low, whichever one that is. If it is the tranny I will be [sm=headbang.gif]. I just had it rebuilt (for the 3rd time) 8k miles and 9 months ago... I had the fluid changed and it looked good but I did have a small leak in the seal so I was probably just a little low. I haven't switched into 4wd to check it out yet but when I went to change the fluid and get an alignment they did an inspection on everything sand said I need new lower ball joints and a left inner tie rod end. $1000 for them to do it. $150 for parts for me and whatever special tools I'll need (please enlighten me on these tools since I have the basic tools at this point).
Old Jul 27, 2007 | 10:29 PM
steve05ram360's Avatar
steve05ram360
it cant be the tranny because it doesnt make the noise in 2wd... it has to be t-case forward...
Old Jul 28, 2007 | 01:41 AM
Mean Green's Avatar
Mean Green
Like I told you before I'm thinking it might be the front diff as well. I'll be climbing under there in later to check the fluidlevel. I should have had them do it at the shop while I was there but I didn't even think about it.
