NEED HELP with my FRONT BRAKE install!
Old Oct 18, 2004 | 06:19 PM
vectorz's Avatar
vectorz
Default NEED HELP with my FRONT BRAKE install!
I was doing the front brakes for my 99 SLT this weekend, and there's something that has me very worrried. I've done disc brakes on all my vehicles, but the Durango is different. On all other vehicles I've done, there are two large BOLTS that generally hold the caliper to a large bracket, that are also held on with two bolts to the hub.
But on the Durango, there is no large bracket in the middle. There is only the brake caliper bolted directly onto the hub, by two SMALL bolts with a HEX key head! So that didn't worry me, I was actually very happy because to take off the rotors I didn't have to remove anything else. So i got the rotors turned @ Pep Boys, and than put everything back together. 2 HEX head bolts, voila. But the hex head bolts don't bolt all the way down. Their tread ends pretty early, and therefore, the caliper sort of is LOOSE against the rotor and hub! It looks tight, but since the two hex bolts have no more tread, they leave space that you can actually press against the caliper really hard and see it slide back and forth along the bolts. It creeps me out. So I put the wheels back on and everything is fine and dandy, however, I'm still worried that I did somethng wrong. Just having a caliper sort of loose and not fully tightened down doesn't seem right to me.
Anyone can provide input if this is normal? I'm used to having bolts on calipers that completely tighten down the calipers so that their isn't any slack or movement. I'm just concerned cause the wife uses the Durango to haul the kids around and I don't want to take any chances.
Old Oct 21, 2004 | 05:39 PM
tst31's Avatar
tst31
Default RE: NEED HELP with my FRONT BRAKE install!
I just recently replaced my front brake pads for the first time, and was astonished when I discovered the same issue. Apparently, it's normal, but I continued inspect them regularly afterwards, since it seemed very likely the pads would not seat flush against the rotors with that much movement available. In fact, my right front wheel squeeked quite a bit at first, although I put on plenty of anti-squeek goo on it, and only after I removed the caliper and reset it, making sure it was flush to the rotor, did it go away. No problems since, but it definately was something I wasn't used to seeing in all my days of self-repair brake jobs.
Old Oct 24, 2004 | 04:25 AM
rockadaous's Avatar
rockadaous
http://home.comcast.net/~quadcab/powerslot.htm
