P 0455 Code
Old Aug 16, 2007 | 10:30 AM
BMunoz's Avatar
BMunoz
Default P 0455 Code
About a week ago my engine light came on; some one told me about the turning the key 3 times w/o starting it trick to get the code and it sent me a P 0455 Code. What does this mean, anyone know??!!! I have a 2000 D. Thank!!!
Old Aug 17, 2007 | 01:45 AM
Mean Green's Avatar
Mean Green
Default RE: P 0455 Code
P0455 Evaporative Emission Control System Leak Detected (gross leak)
Did you leave the gas cap off??? Other than that change the gas cap and reset the code, If it comes back start looking over your fuel lines from tank to engine and replace as necessary.
Old Aug 20, 2007 | 07:19 PM
Frenchy's Avatar
Frenchy
Weird, my mom's 2001 Durango just threw this code today...
How do I reset the codes? Unplug negative for a little while, or what?
Old May 12, 2008 | 07:24 PM
daisydurnago51's Avatar
daisydurnago51
OK! I have an '01 Durango that has the P0455--a "gross" (big) leak in the Evaporative Emission Control System--gas cap obviously didn't work since we tried that and engine light came back on and code changed to the "gross" leak. So now do we replace the hoses and clamps and see or go for the whole system? Does anyone have pictures of the parts?
Old May 12, 2008 | 07:25 PM
daisydurnago51
Old May 12, 2008 | 08:57 PM
n8ech's Avatar
n8ech
Check the emissions canister underneath by the transfer case. You will find two hoses that attach there and lead to two hard plastic hoses that run aong the frame.
You can get them from the dealer for $40, or make them yourself from short heater bypass hoses at AZ for $20.
Don
Old May 26, 2008 | 12:14 PM
BOOMER13's Avatar
BOOMER13
Check the vaccuum lines leading to the evap canister. They may be cracked and/or leaking.
Old Mar 11, 2009 | 08:37 PM
INDIANA DAVE's Avatar
INDIANA DAVE
How can you reset codes besides unhooking the battery?
