AC blows cold in front warm in rear
Old Aug 16, 2007 | 01:28 PM
ceedeelight's Avatar
ceedeelight
Default AC blows cold in front warm in rear
Hi,
I have done a search on the forum and I haven't seen anyissues exactly like mine.
My 2002 Dodge Durango SLT blows cold air in the front and warm air in the rear passenger area. What is this issue? Can anyone help a lady out?
Thanks,
Old Aug 16, 2007 | 01:59 PM
Lil Red Mopar's Avatar
Lil Red Mopar
Default RE: AC blows cold in front warm in rear
Could be a bad expansion valve in the rear evaporator, or air bleeding by the rear heater core.
Old Aug 23, 2007 | 08:44 AM
thefoots's Avatar
thefoots
I sort of had the same problem. On the passenger side, you can remove the interior body panel to access the housing that carries the rear heating and cooling air. There are 2 servos that open dampers that direct air from the heating core or from the AC system. The doors have been breaking alot lately. How you can tell if it is broken is that there is a small tab (white) where the servo attaches to the door. This tabs breaks off when the door breaks. I was able to get a new one at my dealer but he made me buy the whole housing ($112). I could not find one at the junk yard. Another thing to check is underneath the Durango on the passenger side right at the back you can see 4 pipes coming in. 2 should be hot when you run the heater. 2 should be cold when the AC is running. If you run the truck and these dont change temps, then there is a problem with the front system. Hope that this helps.
Old Dec 3, 2007 | 12:14 PM
ceedeelight
Update: Just in case anyone else has this issue, Once I got the Timer and alarm module replaced, the A/C is now working correctly.
