Lower control arm bushing
Old Aug 21, 2007 | 12:19 PM
danab242's Avatar
danab242
Default Lower control arm bushing
Lower and upper control arm bushing
Anyone know how much it cost to replace these? i live in riverside, calif
Old Aug 21, 2007 | 12:40 PM
bigbaddurango's Avatar
bigbaddurango
Default RE: Lower control arm bushing
your looking at about 120 for the parts then you have to have them pressed out and labor around 60 an hour i wild gess up there i would say to take it and have it done rufly $600- $700 but you could do it your self for like $150 or so
Old Aug 21, 2007 | 01:34 PM
Mean Green's Avatar
Mean Green
It isn't too bad to do yourself but after you do the job make sure to get an alignment as everything will be out of whack. Take your time and spend a day on it.
Old Aug 21, 2007 | 11:02 PM
chemoman's Avatar
chemoman
I reciently replaced the bushings on my 99. The MOOG bushings were less than $40. Having them pressed out and in was $45. The hardest part was waiting around while waiting to get them pressed. If you need shocks, do it now too.
Old Feb 6, 2013 | 12:05 PM
danab242's Avatar
danab242
Unhappy Still with problem looks like my tire jumps
Ok i recently had the ball joints and control arm shocks now driver side caliper replaced i still have the same problem when i back up.. tie rod ends replaced too . the bolts to the control arm were loose had those tighen problem went away for a few days now its back..does anyone know what is causing this..
Old Feb 6, 2013 | 10:29 PM
Augie Dog's Avatar
Augie Dog
I replaced my complete front suspension last summer. You didn't say if you have 4WD or RWD. Mine is RWD and I purchased Energy Suspension bushings complete kit from Summit Racing and orderd Moog ball joints from Amazon. Cost for all parts was less than $300. I did the work myself over the weekend. Not difficult just time consuming. If you need help let me know and I can talk you through it. It is factory tight now!!
