hazards flash when signaling right?
Hi all,
I have an 02 durango that recently started flashing the hazards when I signal right. The left signal comes on just fine...weird huh? I would greatly appreciate it if anyone knows how to resolve this problem.
Prob pretty common with aftermarket trailer hitches. However if yours has a factory hitch take it in for warranty, if not your only shot is to spray all the connections with WD40. Yep plain old wd40 will eat whatever corrosoin is causing the short in the relay box. If you dont have a trailer hitch then forget I said anything!
It's an R/T so it's got the towing package. A couple days ago it went in for a warranty repair and they replaced the multifunction switch. Well it started again. Now it needs to go back and they probably don't know what's wrong.
