What replacement speakers to get?
Old Sep 19, 2007 | 11:24 AM
jamez's Avatar
jamez
Default What replacement speakers to get?
The rear doorspeakers in my 2000 Durango are blown (I think - they vibrate a lot when there's a lot of bass). I have an Apline CDM-9803 CD player which pushes 50 W x 4. What kind of replacement speakers should I get? 2-way or 3-way?Ifound these Pioneer TS-A1671R 6-1/2" 3-Way Speakersand am curious if they would be acceptable for the cd player I have. Any help is appreciated!
Old Sep 19, 2007 | 10:13 PM
Kensai's Avatar
Kensai
Default RE: What replacement speakers to get?
Check the post that is stickied to the top of this forums. I even posted a procedure to repair your OEM's on the cheap as you will need to do alot of work to make aftermarket speakers to properly fit the rear doors. Only a select few aftermarket speakers can directly bolt on to the rear doors without any retrofitting. Those are mainly the Infiniti Kappas w or 3 way speakers. pricey speakers too.
Old Sep 27, 2007 | 05:52 PM
eck120's Avatar
eck120
i went with the alpine type r's there crisp and clear
Old Sep 28, 2007 | 12:41 AM
IndyDurango's Avatar
IndyDurango
Learn to use the search function, this is a COMMON topic.
Get 2ohm speakers. And yes in advance, 2ohm if you are using the factory amp. And yes again, 2ohm are more expensive and harder to find (go Infinity)
IndyDurango
