99 durango
hopefully someone can help me out i got a 99 durango 5.2 4wd when i got it and you put it in reverse or sometimes drive it would clunk like the uv joints were bad i took it to the place i bought it and they sent me to aamco transmissions they said it was my transfercase that the chain in side is probally stretched well the place i bought it from got me a brand new one and the clunk is worse what im wondering is this a sign that the rear end is going sense this is a common problem with the durangos
its worth looking into more if there is a clunk when it goes in gear means theres play somewhere try to trace it (have someone listen under the truck will placing it in gear) use elimanation if u are positive the universals are good and were checked properly and the transfer case was rebuilt it does only leave the tranny and rear end and the tranny doesnt usally do that sorry i cant be more help u you
Eck,
Welcome to the forums. I've had some various models of 4x4's and my Durango is the latest one. As far as the clunking goes, Mine does it all the time, only when you put it in reverse. The dealer says this is normal for the Durangos. But on my R/T, my 4x4 is always engaged as it is a full time AWD. There are times also when driving, if I completely let off the gas to let the D start to coast, it will sometimes make the clunk as well. All this noise is the transfer case disengaging/engaging.
You only mention your D is a 4x4 but is it a part time or full time? If it is full time, don't worry about it, this clunking is normal. If it is a part time, it should not be making this noise unless your D is engaged in 4WD. So start from there, if your D is a part time, check to make sure your D is not engaged in 4WD mode, otherwise, this clunking noise when you put it in gear is normal.
