2001 4wd not working
Old Nov 25, 2007 | 06:19 PM
robbiefuchs's Avatar
robbiefuchs
Default 2001 4wd not working
I cannot get my Durango to shift into 4wd. It does not appear that the transfer case switch has power to it as the indicator lights are not illuminated. I checked the fuse and popped the panel off to make sure that the switch was still hooked up. Is it possible for the switch to malfunction? What do you guys think?
I had a post last week regarding electrical problems......radio and blinkers randomly going off and that was fixed with the replacement of ignition.
Thanks,
Robbie
Old Nov 25, 2007 | 08:34 PM
hydrashocker's Avatar
hydrashocker
Default RE: 2001 4wd not working
check for power at the T-case. It could just be the actuator switch. I am thinking that you have a electrical actuator instead of a manual handle?
