check engine / new rig
Old Nov 27, 2007 | 02:01 AM
mojojojo's Avatar
mojojojo
Default check engine / new rig
just picked up my new rig tonight. kinda new to the durango seen. its a 99 5.9L. can u pull codes without a scanner? how do you reset the check engine light? runs and drives great. but i wanna figure out this check engine buisiness asap.
thanks in advance.
Old Nov 27, 2007 | 02:26 AM
v8streetracin's Avatar
v8streetracin
Default RE: check engine / new rig
99 and eailer needs a scanner 2000 + 3 key cycles im pretty shure just pull the battery terminal. but dont you want to know what code(s) are showing up?
Old Nov 27, 2007 | 12:32 PM
SinCity R/T's Avatar
SinCity R/T
To reset the codes, pull the neg battery terminal and then turn the key to START for a few seconds. Turn off/remove the key then reconnect the battery.
99's need to use a scanner. Autozone will usually scan vehicles for free.
Old Nov 27, 2007 | 07:49 PM
mojojojo's Avatar
mojojojo
thanks. got a buddy coming by tonight to pull the codes and see what we got.
P.S. that /\ is the baddest charger i've ever seen!!!!!
Old Nov 28, 2007 | 09:26 AM
hydrashocker's Avatar
hydrashocker
Agreed. Nice car! [sm=Awwww.gif]
Old Nov 30, 2007 | 03:30 PM
Kensai's Avatar
Kensai
Just FYI,
Walmart sells a code scanner for domestic vehicles for under $99
also, if you buy a hypertech programmer, it can also scan codes and reset the errors as well.
