idle
Old Dec 4, 2007 | 02:29 PM
ghoghunter's Avatar
ghoghunter
Default idle
HELLO, i have a 2002 durango. once in a whileit will drop rpms .Mostly when were at a stop. any ideas. thanks
Old Dec 4, 2007 | 05:41 PM
deerang's Avatar
deerang
Default RE: idle
it may be that your tranny needs a little adjustment, it may just mean that you need a tuneup. We need a lil more info about recent history with teh vehicle, and maintenance. What kinda mileage you have. basically just write us a short story about your Durango.
Old Dec 4, 2007 | 05:56 PM
ghoghunter's Avatar
ghoghunter
Default RE: idle
well, it has 67,000miles 2nd owner it had 58,000 mi when i bought it 18 months ago.extreamly clean. i put on a k&n cold air intake. i change the oil on time never over 500 mi.idles great 99% of the time just goes from idle to around 1200 rpm but only in drive at a light or drive thru.thanks
Old Dec 4, 2007 | 05:58 PM
ghoghunter's Avatar
ghoghunter
Default RE: idle
forgot to mention it has the4.7l
Old Dec 7, 2007 | 05:02 PM
noregrets's Avatar
noregrets
Default RE: idle
Ghog, I recently had the same problem on mine. Same engine in mine. It was a vacuum line that had become disconnected (check engine light did not come on). Check those lines and make sure one did not come disconnected.
Ang
Old Dec 15, 2007 | 08:21 PM
skyranger's Avatar
skyranger
Default RE: idle
Hi guys,
Just a case study:
I had similar issues(2003, 4.7 liter). I seafoamed her (very cool smoke) and settled the idle out a bit 600ish rpms. I cleaned the TB, TBI and IAC. Dirty, but negligable effect. Then I replaced the original plugs with the factory Champion copper plugs (RC12MCC4, gapped @ 0.040). The plugs coming out were VERY clean, but the electrodes were very worn, gapping @ 0.075.
Result:
Smooth as silk idle @ 850 rpm's.[sm=yeahsmile.gif]
Hope this helps...
Earl
Old Dec 15, 2007 | 09:55 PM
ghoghunter's Avatar
ghoghunter
Default RE: idle
thanks for the replys. i found a cracked line and replaced the plugs. so far it seems to of fixed the problem
