Overdrive Button
Old Dec 10, 2007 | 04:04 PM
99rdking's Avatar
99rdking
Default Overdrive Button
I have a 99 Durango that the Overdrive Button will only work in Park and Reverse. Once past reverse it will not work and stays in which ever mode it in, whether on or off.
Thanks
John
Old Dec 22, 2007 | 11:23 AM
dodgebrothers's Avatar
dodgebrothers
Default RE: Overdrive Button
Something is amiss. Those are the only gears you don't need it for.
Old Dec 22, 2007 | 06:24 PM
Radar696's Avatar
Radar696
Sounds to me like there may a wire shorting out in the steering column.
You may have to pull the column apart to find out for sure.
Good luck.
Radar
