99 Durango Front Lockout Hubs
Old Dec 14, 2007 | 10:09 AM
max_terry's Avatar
max_terry
Default 99 Durango Front Lockout Hubs
Is there a lockout hub available that will fit a 99 Durango 4X4 front axle?
Old Dec 15, 2007 | 07:45 PM
n8ech's Avatar
n8ech
Default RE: 99 Durango Front Lockout Hubs
MT:
Locking hubs were not a factory option, and I am not aware of any aftermarket offerings. Even if there were, it would most likely be quite pricey, and you would also need different front wheels if they were manually operated.
If you are looking for economy, the folks with the 2x4 D's don't see that much difference. In the case of the 4x4, the weight and aerodynamics would be the same, so any mpg gain would probably be minimal.
When I swapped from part time 4x4 to AWD, the MPG change was negligible
Don
