Blower won't blow at feet.
Old Dec 15, 2007 | 12:27 PM
Dleigh18's Avatar
Dleigh18
Default Blower won't blow at feet.
I have a 2001 durango that is perfect.....except just recently the blower will not come out the feet area. It blowes vent, and def. but not feet....Where is this located, maybe i can wiggle jiggle it? What are you thoughts. thanks
Old Dec 16, 2007 | 02:19 AM
Mean Green's Avatar
Mean Green
Default RE: Blower won't blow at feet.
The blend door might be stuck or you have a bad vacuum line or the line might have popped off. I don't know how much of the dash would have to be removed (if any) to reach the blend door but if anything has to come off it will be a real bear...
Old Dec 17, 2007 | 11:27 AM
MongoDV8's Avatar
MongoDV8
You better check out my thread here. https://dodgeforum.com/m_1085440/tm.htm
I have the same problem and the dealership made it worse.
Also there seems to be some conflicting info out here whether they are controlled by vaccum or electronics.
Old Jan 5, 2009 | 09:02 PM
rebelboy's Avatar
rebelboy
blend doors are controlled by vacuum lines and taking apart the dash is no picnic especially if you have hands like mine i crushed every thing i touched
