where is the air bleed screw 01 5.9
Old Dec 23, 2007 | 09:52 PM
Nickgem13's Avatar
Nickgem13
Default where is the air bleed screw 01 5.9
hey buddies does anyone know where is the air bleed screw at on a 01 durango 5.9 r/t
Old Dec 23, 2007 | 11:30 PM
n8ech's Avatar
n8ech
Default RE: where is the air bleed screw 01 5.9
Nick:
If you are referring to the cooling system air bleed, I don't think they have one per se other than to leave the radiator cap off and idle while you fill and let the air work its way out.
If I am wrong, others will chime on and correct me. I have the 4.7, and I know where that one is for sure.
Don
Old Dec 24, 2007 | 09:18 AM
burban2002's Avatar
burban2002
air bleed screw for what?
Old Dec 26, 2007 | 01:34 AM
Mean Green's Avatar
Mean Green
Just pop the radiator cap, it is at the highest point in the system and warm up the D adding coolant as it goes down.
Old Dec 26, 2007 | 10:54 PM
hydrashocker's Avatar
hydrashocker
He means on the T-stat housing.
And no there isn't one on the 5.9L
Old Aug 5, 2012 | 04:58 PM
Floyd Hunt's Avatar
Floyd Hunt
Default Bleader valve 5.9 durango
There is not a bleader valve on a 5.9 cooling system.... To properly (burp) your system..starting with a cold engine, remove the rad. Cap, turn on the heater, fan off...if possiable, find a container that fits the rad cap hole firmly where no coolant will leak past and pour coolant half full, start engine and allow it to run until it reaches normal temp, keep the level of coolant in the container above the highest point of the coolant system.... Which is the bend going into the thermostat, after the thermostat has opened and the all the air has been purged, you can remove the filler container and replace the radiator cap,do this quickly to keep air from returning into the bend of the hose. Refill the reserve and turn off the enging....... ALLOW TO COOL, THIS SHOULD PROPERLY PURGE ALL THE AIR
Old Aug 6, 2012 | 06:06 PM
topdogcustoms's Avatar
topdogcustoms
this thread is from 2007 i dont think the member is around anymore
